Click here to Donate
Jcayennes
  • Content Count
    11
Everything posted by Jcayennes
  1. Hey guys, My headliner in my 2006 CS (grey) has dropped over the cargo area. I took off some trim panels and sprayed some glue into the detached area, but as expected... the foam is shot and the glue just made things worse. I have called for quotes and one place wanted $1000, the other (mobile) guy wanted $525 (replace with basic suede..pillars too). The other interior specialty shop said he wouldn't let his guys touch it as there is a lot that can go wrong and he is worried about the sunroof operation. How hard is it to remove the headliner and pillars from the car? I could do it and have t
  2. UPDATE: Well, I ran with a cleaning agent for 100 miles and when I put 3oz's of the stuff in the tank, the noise (sticking, rubbing) stopped. I followed the directions and flushed the system. I blocked off inlet hose on tank and pumped old fluid into pail, moving steering back and fourth. I kept the bottle full while doing this. Noise is back. It's only turning right..when there would be a sloshing effect. Think of a sweeping turn, moving fluids to one side of a pan, reservoir or bottle. That’s the only turn that makes this act up. Parking lot slow driving doesn’t. When taking an on
  3. I think I am figuring it out.. Back when I bought the car (45k miles, 75k now), I remember hearing a whining sound (It was actually the normal Cayenne whiny sound) I put some lucas gunk stuff in the reservoir to get rid of the noise. Ovbiously it didnt do anything because thats the normal sound of the car. I am thinking it gunked something up..valves...cooler.. who knows. (stupid to use that stuff, I know) I am going to do a complete flush with the trans tune stuff (removes varnish) and hopefully it fixes it. It only happens when after running for 10 miles or so and the fluid is hot..right h
  4. I will get a video clip tomorrow. Its a definate "squeak" or a "wet sneaker" sound that I can feel a little friction in the wheel..only when going right, after its been warmed up (normally a quick expressway trip) and I make a right hand turn at any speed. Yes, I do have Servotronic. Could I have a clogged valve in the rack? Or a gummed up or dirty PS cooler? Sorry about the delay.. long recovery after holiday weekend :) Thanks, Joe
  5. I will get a video clip tomorrow. Its a definate "squeak" or a "wet sneaker" sound that I can feel a little friction in the wheel..only when going right, after its been warmed up (normally a quick expressway trip) and I make a right hand turn at any speed. Yes, I do have Servotronic. Could I have a clogged valve in the rack? Or a gummed up or dirty PS cooler? Thanks, Joe
  6. I dont think its the pump.. I can feel the sticky, squeak in the rack.. After driving a bit and the vehicle is stationary. When driving, it happens only going around a right hand turn..(sweeping).. Does the Cayenne have a screen in the PS fill bottle? Maybe the sloshing of the PS fluid when turning right is lowering the pump pressure?
  7. Hey guys, after slowly hearing a ocassional noise over the last year on hot days, its starting to get louder. I know its the rack and it only squeaks when its hot and I'm turning right... (sometimes it makes noise when pulling out of parking spot) I have done a few fluid "baster" changes with the CHF fluid and it fixed it for a week, then it came back. Car feels great, no noises when first fired up on a 80 degree morning.. It seems to start making the noise after driving a bit and heating up. Fluid Breakdown? Think a proper flush will fix this? I have already thought about a new Rack o
  8. Thanks for your response.. Yes I am getting a nice green light when pushing the buttons.. I will Try to turn key to the right.. And then press the lock or unlock button. I just don't want the car stuck there with the alarm blaring..I will be towed I'm sure if I can't shut it off. Do you know if it will turn off the alarm when I try to start the car? It's the oem factory key.. Thanks!
  9. Hey guys.. I need some information ASAP. I went to home depot today and locked my car. Came out 10 min later and the transmitter wouldn't work. Alarm door lights are blinking so I know the alarm is armed. I got a ride to get a new battery for the fob and it didn't change a thing. I tried to insert key into door and turn and it will unlock but alarm is still flashing.. I know the Siren will sound when I open the door, how can I turn the siren off? Will inserting the key into ignition turn off the siren? I'm stuck at home depot and in a parking garage.. I'm just curious how I can turn the siren
