ekstroemtj
Everything posted by ekstroemtj
  1. This is how she looks in summer dress with 23 wheels
  2. Please can somebody give me a hint what is the correcr part number for the big radiator fan. I understand there are 3 numbers. The full assembly with 2 fans and housing The small fan The big fan Thank you
  3. PSM failures are pain in the ***. I had it several times when i take the vehicel to a car wash place. LOREN told me one time a possible reason could be that one of the Sensors get wet. Not only sensors are a possible place for your problems. Water influence at throttle body, Mass air flow sensors etc. I am not a professional but in my cases it always helped me when i did this: Closed the car from outside with remote. Open it again. Key inside and switch on ONLY ignition. Leave it for about a minute. Key out. After start and in 8 of 10 times it was working with me
  4. Thank you guys for all your comments. I will try to check. I should have choosen a car mechanic profession instead of banking business. Would be much more useful if you drive cayennes.
  5. hi , i guess you got me wrong. i would like to know if the fan /resistor is one part or i can get it separate? thank you
  6. Great! I will check. Resistor is sitting on the fan? They trade with the fan or i can get it seperate if the part Is faulty?
  7. Outside temp was arround 95 . The temp gauge needle went very close to the red mark
  8. It was on yes but when temp got up like crazy i switched off and change to heating. I remember thats cooling down a bit
  9. I found onother troublemaker . Jesus what a car. Secondary radiator fan doesnt start. Germany now very hot and i was in a traffic jam today. Temp gauge is climbing and climbing. I open the hood. Nothing. What i hear and see, only one fan is running. Checked the fuses at home. Everything fine. Any idea how to make a quick check what it can be?
  10. Checked on my other cayenne. Found where it has to be . Thankx
  11. Open the hood and get access to the place where the fuse Box is in the engine compartment drivers side. Here i found this part Hanging arround. What is it? Where it has to be installed? Thank you
  12. Hello everybody! Wanted to say that the problem is solved. Car i back since yesterday. With a new second alternator and .... IT WORKS! They made a test and i was driving now arround for some time. doesnt matter which rpm, the meter never goes under 13,3 and the high is arround 13,80 I hope this is some way ususal for this engine. Thank you to everybody who posted help and advice. Thank you for yor patience. Am am very glad and happy that YOU are here. Thomas
  13. JFP..... I read somewhere in the forum when people spoiled the lenses by wrong treatment. Do you recommend something special? Thank you
  14. Follow up: The original Alternator which was in the car (the pictures i posted) went to Bosch. They wrote me today. Part is ready to install. Indead it was faulty. They changed everything inside + new regulator. Now next try. I hope and pray
  15. Did you check youtube videos for similar noises? There are some files with Cayenne engine noises. Some serious, some not. Best solution, try to make your own video and post the link here
  16. Mmmm. Thanks for the detailed information. I am already dreaming from batteries and alternators. Makes me crazy:-) Tomorrow the alternator will go back and hopefully in some days i will have a new one. Anf than pray that this problem is fixed.
  17. I thought this regulator is a plug and play part. But as i see it must be fixed with a soldering bolt.
  18. Ahsai. The pictures are showing the original alternator which they took out 2 weeks ago. Its the OEM part from the car which was running there for the last years. Now i have a remodeld inside which is not working proper too as i described. It was reman by BOSCH according my information. If you look for a alternator for a Cayenne here in Germany, you can find Delphi, Hitachi and Bosch.
  19. I wanted to have a look inside to the old one but i dont The right tools to open the black cover. Ahsai you are right, it should be their problem. What i see now its a fight Between the porsche shop and the manufacturer of the alternator About the labor for changing this part a second time.
