Zenski
Everything posted by Zenski
  1. Thanks, I will check that out.
  2. Hi, I just replaced my ignition switch and now my cruise control doesn't work. Just wondering if anyone else has had this happen and what the fix is. '99 C2 Cab with a manual trans. Thanks
  3. Hi, I used to hear the sound at start up and now I don't. Now I have a check engine light on and it's the P1411 code. Could this be the relay is bad or the pump itself? I know their are lots of things that cause the code, but just trying to narrow it down. Thanks Andy
  4. Just finished the swap and it worked perfect. I like the 220 a lot more than the 210. Thanks again for the help.
  5. Thanks, I already had the metal cage out, so shouldn't be a issue to get it out again.
  6. Hi I purchased a used CDR-220 to upgrade so I could use the aux. wire to play music from my phone. I picked up my car from storage this last weekend and proceeded to try and change it. It looks like the 220 is a bit wider (1/32). Where can I find a diff. metal insert to accommodate the 220 or can I modify what I have? Thanks
