gllever
Everything posted by gllever
  1. Recirculation is off and the floor is dry . It happens so fast when I start the car it seem the moisture is in the AC/Heater system .
  2. I have two 2004 cayenne s . One has a problem with instantly fogging up the whole interior after it has been run a while , shut off , and restarted when it is raining. The other one does not have this problem. Do I have a plugged drain some where?
  3. Part is now $32.00 plus shipping, not worth it. Just glue a piece of triangler plastic in the button.
  4. Problem fixed , I hit a large truck tire tread doing about 60mph on the freeway. Then heard the mixer valve making a noise, turned the heat setting for the right side to 80 deg. Low and behold out came warm air. Now can anyone explain that?
  5. Thank you for your reply. That is a lot to ask of a large over weight 73 year old with poor vision,but I will try
  6. 2004 s Passenger side will not heat but has good cooling. I have seen this subject here before but didn't under stand the answer.How do you see the servo motors that move the controls or get to them? Or could it be a fuze, if so which one?
