Nick_USA
Everything posted by Nick_USA
  1. ...and still no OBC enable
  2. All of you need glasses as the 'rectangle' as you call it has a corner missing (top left) so I correct you all in saying it is just a yellow line!!
  3. ...and the extra step is ?
  4. Does anyone have the PCM Nav system fitted to a car without the OBC stalk fitted to their car. My OPC reckons you have to have it enabled in the car otherwise it will not function, is this true??? Can anyone offer advice as at the moment I have a PCM fitted to my car that just doesn't want to work.
  5. Do I assume correctly that the clear one fitted to the 987 is a different size/mount?
  6. Well the price is $20 higher than the dealer! :eek: If I heard my parts guy he said $75 for a new one, $125 for the earlier models. If you already purchased one, did you get it installed? CJack So if it is a Porsche OEM part what is the part number ?
  7. Do I assume they also do a six speed shifter ? 986.424.981.06.VRJ ???
  8. Loren, I am confused is this purely for the OBC or the 'with cruise option' ?
  9. And then do you have to search again for the DME and enable the OBC there?
  10. I know to enable the OBC on my 2004s (post the OBC stalk fit) I have to enable the trip computer in the instrument cluster but I also think there is somewhere else you need to do it? Can you help?
  11. My OPC said I have a problem with my CAN BUS. I thought my car only had one bus ie the MOST bus. My car is a 2004 Boxster S
  12. I think the fiber cable is good as they managed to enable the unit, the standard one in the car should work ie radio/PCM with amp not cd changer and not telephone. The OBC enable I would like them to do anyhow and this maybe it. The car is back to the dealer on wednesday so we shall see. The good news is that because I bought the unit from a dealer it is covered by a warranty. Thanks Loren
  13. Does the activation of NAV in the the instrument cluster require the use of the 986320 code? (I do not have the trip hack fitted to this car yet) The fiber optic cables were the same ones from the cdr-23 I'm not sure as to the rear speakers but I will print this and any other post. My only other thought does the trip computer functionality have to be enabled?
  14. I have just installed the OEM Porsche PCM Kit into my 2004S Boxster S and tried to have the system intialised at an OPC. I now have the following issues: 1. The GPS locks on and I get 3D-GPS indicated it reads the map but cannot work a route. The guy at the OPC says the is a problem with the CAN line. I see the symtoms as no trip data (fuel consumption etc is fed to the PCM). The OS is version 3 I have the latest maps but no joy. I do not have the OBC stalk fitted to the car though. Is there something he is missing as I thought you didn't need the OBC to use the PCM. 2. The audio configuration shows front speakers only ie balance onlyand no fader. I have rear speakers fitted. The technical can't find anywhere to let the system know I have the rear speakers fitted. Can you help guys?? :(
  15. Doesn't work post year 2000.
  16. I can confirm that they do in Europe, so Loren is the wiring different? I know there is a hack but can it be done properly?
  17. Thanks. Toolpants can you confirm ?
  18. No leather and just standard black
  19. Part starts 996 552 181 but searched for the part and comes up with loads of options... what is the part number???
  20. What is the part number for the tire sealant, the pump that goes with it and their cost ?
  21. Do I need the trip computer enabled and the stalk fitted to run the PCM Nav System on my 2004 S?
  22. Will the 987 LED version fit the 986 ?
  23. If it is ok now then leave it alone..... just bear it in mind if you ever disconnect the battery in the future.
