Nolti Nast
    albania
    seat ibiza
  • Future cars
    porche carrera
Nolti Nast's Achievements
  1. i checked it to the display the serial was the same just the type was 4467 not cdr 22 ! so to the display it says type 4467 and serial 25005710
  2. Then you likely did not perform the the serial number display (per the FAQ) correctly - or transposed the numbers. If you want to check I'll rerun your serial number again. ok this is all i can found on my becker now im clear i did a mistake while givin you the type is cdr 22 and not 220 !!! sorry , and hope you can help me now...thanks man ! If you read the FAQ there is an easy way to show the serial number through the display... though it was the same , now i saw that it was becker 1 , Type 4467 , serial 25005710,thank you
  3. Then you likely did not perform the the serial number display (per the FAQ) correctly - or transposed the numbers. If you want to check I'll rerun your serial number again. ok this is all i can found on my becker now im clear i did a mistake while givin you the type is cdr 22 and not 220 !!! sorry , and hope you can help me now...thanks man !
  4. Then you likely did not perform the the serial number display (per the FAQ) correctly - or transposed the numbers. If you want to check I'll rerun your serial number again. ok this is all i can found on my becker
  5. Thank u for the quick reply and for your time but tried and didnt worked...
  6. i have a becker cdr-220 model be6621 , serial 25005710.thank u!
