virkdoc
Everything posted by virkdoc
  1. Hi Am planning to get 20 inch rims, but since the roads here in india are pretty bad was lookin at a higher sidewall. Is it possible to put in 255/45/20 inch tires on the cayenne 20 inch rims? Would they work fine? HAs any one ever tried em? Thanks Ron
  2. Hi Loren can u help? Also should I get 19X8 or 19x9 or 19x11?
  3. Read up on oil filters....it says that the oil on the filter is so minimal like 1.5 ounces that its impossible for it to fly off.....
  4. I live in India Loren and roads suckkk.....needed a wider tire, so an 18 inch would be good? I can use a 255 on an 18 inch? I'm getting a few 18 inch rims here but offset varies from 40mm to 55mm and width varies from 8 inches to 11 inches. Which one should I pick up?
  5. Hi I am planning new tires on my 2006 cayenne 3.2L V6 Right now it has 235/65/17 I want to stick to the 17 inch rim....what's the biggest size tire I can have on it?
  6. also one of the salesman said to get a dry weave filter instead of an oil based filter?? Whats the opinion on the fabspeed sec cat bypass pipe?
  7. Hi Im planning to get a ECU flash om my base Cayenne 2006, 3.2L V6. I have spoken to EVOm and DMS. What is the opinion of the forum? Which would be better or more reliable? I know a lot of people are running these flashed ECUs...what is your experience with them or a reflash in general. Also I want the sound more throatier...will a cat bypass fabspeed pipe help? Thankssss
  8. it doesnt have an air suspension
  9. Engine is a 3.2L V6, umm I dont know if it has air suspension? How to find out? I know its a funny question.....Also the steering adjustment is manual....Its with a dealer and the dealer also doesnt know if its an air suspension.
  10. Hi guys Am planning to pick up a used cayenne 2006 done about 40,000kms here in India. The roads here are bad so the cars are usually hit up bad. I test drove it and being not a very technical person I had some queries: 1) when i pull the handbrake release the light does not go off, then I had to manually pull the handbrake out and then the light disappeared...is it an easy fix or a major issue? 2) there is a yellow light on which shows an exclamation mark which constantly remains on?? What does that mean? 3) The gear shift seemed a little lethargic....and a bit jerky?? Is that normal in a 2006 model?? What other things should I look for in a used cayenne? as in engine, suspension etc. The interiors were dirty, need cleaning, is it easy to clean up leathers and dashboard.....we dont have professional companies here doing it so what is the best way to clean it. the driver seat would not go completely back.is it an easy fix? thanks a ton in advance.
