Turbo-x
Everything posted by Turbo-x
  1. Any others I can try? Thanks. If the code I gave you did not work then your serial number is not correct.Please follow the procedure in the Lost Radio Code FAQ to obtain the correct serial number.
  2. Loren, I triple checked the numbers... Are there a couple others I can try?Thanks again. If the code I gave you did not work then your serial number is not correct.Please follow the procedure in the Lost Radio Code FAQ to obtain the correct serial number.
  3. No luck with 4643... any suggestions? Here's the info again. Thanks. CDR210 r3297 w5023974
  4. Can I please get some help with a radio code? CDR-210 R3297 W5023974 Thank you very much!
