jhun
    Canada
    1998 Porsche Boxster
jhun's Achievements
  1. Try 2655Thanks JFP in PA for the quick reply. Unfortunately 2655 did not work. I also tried 2653 and 2657 and they did not work. Do you have any other suggestions.Thanks.Recheck your serial number for the radio, the one you posted decodes to 2655.I just checked it over and everything is correct.CDR-210SN. V5011249R 28962655 does not work. Need help stillThanks.That serial number still yields the same code, 2655; second choice would be 2555, and third choice would be 2565.Just to be safe, how are you obtaining the radio's serial number and entering the code? According to the manufacturer, it should work like this:"CR-210: Press tone, then hold both the '0' & '8' buttons until the radioname appears. Then scroll to PR-VERSION using the tuning arrow.Now you should be able to retrieve the serial number by selectingthe station preset numbers.- CR/CDR-210, enter code by pushing the signal seek switch"That is exactly how I got the serial number. However, I have not tried putting in 2555 or 2565. I will try again once it unlocks itself.I just tried 2555 and it did not work. I then tried 2565 and it is now unlocked. Thanks JFP in PA
  2. Try 2655Thanks JFP in PA for the quick reply. Unfortunately 2655 did not work. I also tried 2653 and 2657 and they did not work. Do you have any other suggestions.Thanks.Recheck your serial number for the radio, the one you posted decodes to 2655.I just checked it over and everything is correct.CDR-210SN. V5011249R 28962655 does not work. Need help stillThanks.That serial number still yields the same code, 2655; second choice would be 2555, and third choice would be 2565.Just to be safe, how are you obtaining the radio's serial number and entering the code? According to the manufacturer, it should work like this:"CR-210: Press tone, then hold both the '0' & '8' buttons until the radioname appears. Then scroll to PR-VERSION using the tuning arrow.Now you should be able to retrieve the serial number by selectingthe station preset numbers.- CR/CDR-210, enter code by pushing the signal seek switch"That is exactly how I got the serial number. However, I have not tried putting in 2555 or 2565. I will try again once it unlocks itself.
  3. Try 2655Thanks JFP in PA for the quick reply. Unfortunately 2655 did not work. I also tried 2653 and 2657 and they did not work. Do you have any other suggestions.Thanks.Recheck your serial number for the radio, the one you posted decodes to 2655.I just checked it over and everything is correct.CDR-210SN. V5011249R 28962655 does not work. Need help stillThanks.
  4. Try 2655 Thanks JFP in PA for the quick reply. Unfortunately 2655 did not work. I also tried 2653 and 2657 and they did not work. Do you have any other suggestions. Thanks.
  5. Hi Loren, Can you help me retrive my radio code? Thanks CR-210 SN. V5011249 R2896
