Trevor Whitehead
Everything posted by Trevor Whitehead
  1. Thanks for all your comments will investigate further, Ive got a call out to the specialist who did the plug in test to ask him to have another look and let me now what tester he was using Thanks again
  2. thanks for your help, the steering controls for the tipronic don't work, but ive just found a fault guide for the transmission and it if there is a problem with certain solenoids it can go into Limp mode and depending on the fault can put it into 5t. You would have thought a plug in would have registered this or a fault warning! Still reading the guide
  3. Ive got a 2003 Cayenne S, there is no drive from cold, when it warms up a bit I get 5 & 6 gears, I think as there is no indication of the gear being used. Reverse is fine. Ive notices on the dashboard that when I start the engine in Park, the display shows P briefly and changes to D. I had a plug in test and nothing came up, I change the fluid. Any suggestions welcomed
