felo2013
Everything posted by felo2013
  1. I have found that the whistler noise in a proper installed roof transport system comes from the bar upper grooves. This noise is much increased when you install the ski rack over the bars. The solution is to install the provided molding rubber bar in the groove. If you have installed the ski rack you need to install a shorter rubber piece between the two ski rack support. In my case this solved the problem.
