sm300z
    Nashvegas
    Other
sm300z's Achievements
  1. Thanks Loren!!! your Great!!!!
  2. Loren , just wanted to ask before i unhook the battery again. I have to fiinish some work on drivers door and gona unhook the battery but if i do, will the radio code be the same cade that u provided before to reset the radio?? thank ahead of time!! im also tryn to reset the check engine light and airbag. i have been trying to locate the proper software for the scanner but no luck yet.. i will prob order an autel scanner but it will take a week to get here!
  3. Loren, Thank You soooo much you are Awsome... the first code you sent me worked!!!!! Now if i can get the nutty airbag lite off.... I had to remove airbag to replace window reg. so i unhooked batt. Anyway Thanks Again!!!
  4. Loren, hey i waited lil bit over an hour and its still displaying Wait?? am i missing something? thanks
  5. Wow Loren fast response.. THANKS..i still got "WAIT" showin on the screen but i will try that new codes in a lil bit...thank You!!!
  6. Well same issue had to pull the battery for some work i was doing to the eng n door panels so i lost the code to stereo n guy i got it from has no clue.. thank you Ahead of time..Great site 2000 911/997 Ser# for radio Y5039988 CDP2081 4462 24/99 Manu Date thanks!!!
