bykerboy
Everything posted by bykerboy
  1. Try 6548 That code did not work. :( Did you follow the instructions in the Lost Radio Code FAQ to get your serial number? Yes I did. That was the SN I supplied in my original request. Does that SN not look correct? SN: 51001812 If you did it per the procedure then it should work (and has for most all in the part). If it is not working then I am sorry and you will need to to to your dealer/OPC. I'm out of town for work the rest of the week. I will double check the SN when I get back in town. Thanks for the assistance.
  2. Try 6548 That code did not work. :( Did you follow the instructions in the Lost Radio Code FAQ to get your serial number? Yes I did. That was the SN I supplied in my original request. Does that SN not look correct? SN: 51001812
  3. Try 6548 That code did not work. :(
  4. 2nd owner of this 1996 Carrera 2, replaced the battery and don't have the radio code. Becker CR 210 SN: 51001812 Thanks so much!
