DavidHurth
    Fresno, CA, USA
    1999 Porsche Boxster
  • Future cars
    Porsche 911 GT2
    Porsche Cayman S
    1983 Porsche 944
    1977 Porsche 924
DavidHurth's Achievements
  1. Try 6702 Unfortunately, that didn't work. I've tried numbers around that, but no luck. Will try some more numbers later. Thanks for your effort. Did you follow the instructions in the Lost Radio Code FAQ to get your serial number? I am trying figure out what CR-210 owners are doing - because I have gotten many codes correctly and all of sudden they seem to be wrong. Yes, I followed the steps, but I can go through it again to make sure I didn't mistype anything. Just had my car at the dealer and they got the code for me and it was the same one you gave. Do you know if there is a step that you need to do after you enter the code? Perhaps that would help other people having the same issue with the codes not working.
  2. Try 6702 Unfortunately, that didn't work. I've tried numbers around that, but no luck. Will try some more numbers later. Thanks for your effort. Did you follow the instructions in the Lost Radio Code FAQ to get your serial number? I am trying figure out what CR-210 owners are doing - because I have gotten many codes correctly and all of sudden they seem to be wrong. Yes, I followed the steps, but I can go through it again to make sure I didn't mistype anything.
  3. Try 6702 Unfortunately, that didn't work. I've tried numbers around that, but no luck. Will try some more numbers later. Thanks for your effort.
  4. I had to disconnect the battery to replace the ignition switch and now my 1999 Boxster needs the code entered and I don't have it (pretty much the normal story). Becker CR-210 R3297 SN: W5022855 Thanks very much for your help.
