Jack425
Everything posted by Jack425
  1. Maryland/chinesefood- How were you able to put spacing blocks to take out regulator? I followed Loren's instruction to remove regulator and removed every nut and bolts mentioned in the all steps but the convertible-top support is not even moving to fix spacing blocks. Does it requires lot of power and pressure to put spacing blocks? Per Maryland suggestion, it was easy to remove #9 bolt and I removed #9 bolt quickly but I can't get regulator out from the panel. See attached photo of current state of the side panel. Any help would be greatly appreciated.
