madmaxroi
Everything posted by madmaxroi
  1. Actually no. It is not an alignment issue. I attempted to put the top up not knowing I had an issue with only one side being raised. Unfortunately, it went up high enough where the top on one side has a stress dent on the side that went up leaving me to assume that whatever hardware is on the underside caused the dent.
  2. I will get a picture of the damage next time I go to storage. So a bad motor might also be a part of this. I assume the motor not only raises the clamshell, but also the top itself. Too bad there isn't some kind of relay that recognizes the clamshell is not being raised evenly and just stops the process. At least that would prevent the resultant torquing of the clamshell that occurs. A new clamshell part runs about a grand. This 1998 only has about 25,000 miles on it so we shall see. The wife says she would leave the dent as is. The link would be great.
  3. Thanks. I like the easy to fix part. Any good source on the steps to do? Any issues with timing the transmission after cable replacement? I should just replace both cables while I am at it.
  4. Thanks. We're they able to fix the bent clamshell/stowable compartment? If it was a snapped cable, why was the dealer wanting to replace the motor?
  5. Any idea what part failure would cause only one side the the stowable top cover to raise and not the other. Unfortunately, the stowable top now has a dimple dent from the bracket underneath. Bummer.
