Cuore_alfa
Everything posted by Cuore_alfa
  1. Like 5 hrs, the sencond headlight took me like 30 minutes, no warning lights, everything is working just fine. NO DEALER REPROGRAMMING OR VISIT NEEDED is a straight forward DIY. anyone can do it.
  2. If you find out something, please let me know i just bought a DVD player and i don`t know where to start. thanks in advance!
  3. 9) Remove the xenon ballast in the bi-xenon headlights (6 bolts) then disconect the harness, now remove the 5 pins (thin black, thin brown, red, yellow and uncovered ground wire) you only need two wires to turn on the xenon (Strong black and Strong brown) 10) Cut all the wires in the connector (bi-xenon headlight) NEAR to the connector and then use the plastic trick to remove it from the headlight. Take the Halogen connector and use this diagram: PIN 1 - Parking Light Lead (+) PIN 2 - High Beam Adjuster Supply PIN 3 - High Beam Adjuster Sensor PIN 4 - High Beam Adjuster Ground PIN 5 - EMPTY PIN 6 - Low Beam Lead (+) PIN 7 - High Beam Lead (+) PIN 8 - Additional High Beam Ground (-) PIN 9 - Turn Signal Lead (+) PIN 10 - Low Beam Ground/Parking light/Turn Signal (-) PIN 11 - EMPTY PIN 12 - EMPTY (tanks to toby http://www.renntech.org/forums/index.php?s...pic=1189&st=20) 11) Tap every wire as this diagram says, note that inside the headlights (Halogen / bi-xenon) the grounds wires are brown and leads black 12) if you want to, remove this resistor from the bi-xenon shuttle 13) Remember to tap the bi-xenon shuttle + Auxiliary high beam whit the pins PIN 7 - High Beam Lead (+) PIN 8 - Additional High Beam Ground (-) Corner light + xenon ballast whit PIN 6 - Low Beam Lead (+) PIN 10 - Low Beam Ground/Parking light/Turn Signal (-) 14) Check all the wires, solde and insulate all wires. 15 reinstall the xenon ballast, connectors and you are done!
  4. Ok here we go: vehicle: Porsche Cayenne S 2004 (Halogen Headlights - No Air Suspenssions - No Headlights washers) Factory halogens headlight part no. bi-xenon headlight part no. Before start i have to remove the orange look of the headlight... Done! Things you need to know... you DON`T need the bixenon wire harness (part no. 955 631 239 10) to make the bixenon headlights work. I re-wire the internal of the bi-xenon headlight. * The only diference are: 1) bi-xenon have an extra light called (cornering) i tap this to the xenon wires, every time the xenons turn on both cornerin lights goes on. ALSO this prevent the computer detect a problem whit the low bean xenon ballast. 2) I tap the bi-xenon shuttle whit the auxiliary high beam lights, if i don`t have the xenons on and i flash the high beams, only the auxiliary and the shuttle goes on, NOT the xenon. there is a resistor in the shuttle that you can remove (more details next...) * Start 1) Take out both headlights (Please see manual for more info) 2) Take the 3 covers out 3) Remove the Autoleveling motor (remove the 3 pin harness and two bolts) from the Halogen headlight 4) You have to take out the Pin conector, to do this insert a plastic (Use an old Credit card, cut it in two and then resize it to 3cm wide) insert the plastic at the top and bottom inside the housing make sure it reach the end and then pull out the connector (This is a pain in the a..) 5) Once the connector is out start to cut each terminar as long as you can, NOTE: don`t cut the 3 pin connector in this harness you will use this whit the autoleveling motor in the bi-xenon headlight. in the end you will have this: 6) Say bye bye to the halogen headlight... don`t be panic now... 7) Remove the 3 covers in the bi-xenon headlights 8) Now remove the Autoleving motor (remove the 5 pin harness and two bolts), then install the 3 pin Autoleveling motor Side by side (Left Halogen 3 pin, Right bi-xenon 5 pin)
  5. Done! this retrofit is really EASY... DIY next
  6. Ok, afther take a closer look of this thread: http://www.renntech.org/forums/index.php?showtopic=1189&st=0 Is pretty clear that nobody in this forum have done this. so i have to make my own research... Step 1) take the car to the dealer, if they can`t programm the vehicle to xenon headlights this will lead to the step 2... Stay tuned
  7. Is there something i have to know? or i can just re-do the wire harness to make the new headlights work?
  8. I need some help whit the retrofit, is this possible or not? any news?
  9. Hello there i just get a set of bi-xenon headlights for my 04 Cayenne S, i also get a set of wire harnes, but there is something wrong because the xenon don`t turn on and the blinkers turn on whit the "Side" aux light, i need to take the car to the dealer to solve this isue or i get the wrong wire harnes or headlights. thanks in advance!
  10. I have to remove the Front Bumper to take off the 5 grills? Please let me know! thanks in advance
  11. I do, Cayenne S 2004, two master and one plastic key
