gtnag
    Chandler
    1999 Carrera cabriolet
gtnag's Achievements
  1. It should be 4150 - so it looks like you will need to contact a dealer or Becker -- sorry. Loren. The code was correct. Apparently multiple codes had been tried before and the lockout went into effect. Working now. Thanks again.
  2. No need to apologize. Thanks for your help. I'll update what I find out once it's fixed.
  3. I did and just to be sure I repeated again. Same serial number. The system is a CDR-210 and not CR-210, but the instructions worked.
  4. Thanks for your promptness even on a Sunday. (Wow) Unfortunately code didn't work. I double checked the Serial Number and tried every code from 4140-4160. Any thoughts? Thanks again.
  5. Loren. New old car and replaced the Battery. Thank you thank you CD-R-210 Model R3297 Serial W5023142 Thanks again.
