Search the Community
Showing results for tags 'cayenne cooling'.
  • Search By Tags
  • Search By Author
Calendars
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. 2003 Cayenne Turbo - Cold climate package It all started out with the classic failure of the plastic cooling pipes. My wife was driving the car when a severe coolant leak emerged - and after the failure she "had to" drive the car a few more minutes before stopping. What happened in those minutes will never be entirely clear ..... so be it. When I arrived at the scene to access the damage I switched on the car (without starting) to hear a DRY pumping noise - and immense rattling coming from the driver side fender. Clearly an electrical (additional coolant pump) running dry, so I just switched off the car and had it towed. 10 days later I finished the coolant pipe upgrade/repair and refilled the cooling system without using the vacuum filling procedure that is recommended by the workshop manual. Result: No heat coming from the cabin heater. So I suspected some air blockage in the system. But after following the workshop manual bleeding procedure - and other maneuvers, s.a. lifting the front of car while reving engine/removing driver side radiator hose etc/running pressure through the system etc = no improvement. Also, the engine heat gauge is overly hot when idling - but returns to normal under higher rpms. So, is it possible the the additional water pump has failed ? Is this pump feeding the heater core and the heat sensor cooling manifold ? Is there other likely cause for this failure ? All and any help would be appreciated :)
