Search the Community
Showing results for tags 'expansion valve'.
  • Search By Tags
  • Search By Author
Calendars
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. Today I took the Cayenne 06 TT with 4 zone climate control to a shop to replace the damaged AC service valves and vacuum then regas the system to spec 1050-1100grams with 10g pag oil. See image of new valves for low (right side)and high side (left side), as you can see they are vw parts and they pretty much fit any vw model and Porsche Cayenne and probably a whole load of other brands as the valves are generic for a lot of manufacturers and fit AC equipments which are standardise for obvious reasons. I went to Porsche and they didn't have any stock so went to vw and they had plenty. Move the power steering reservoir out the way for easier access. Second picture. The old low side valve (image 3) with manky looking chewed up Rubber valve which was stopping regassing according to the shop I tried 4 weeks ago after collecting from the garage who did the torque convertor seal job and left me with no AC working but before when I collected it (then had to return it due to massive vibration and a list of other crap), it did work which is strange but undercharged is all; (51oC when I collected it the second time with Jack all AC working thanks a bunch guys)! So getting to the issue. . ...... Vacuum was fine no leaks, re-gassed to 1100 perfect, started car and ran AC, nothing but hot air. Gauge for high side was perfect in the green zone, but low side was much to high above the green zone and in the red. The technician concluded the compressor was good but the low side is blocked. He said the expansion valve is likely blocked and thus the low side is high. Makes sense. So a few questions pls... Q1. Is there any way a fault code or switch device/ sensor or valve located after the compressor could be off or shut and not allowing the refrigerant to not flow around to the condenser then onto the expansion valve and through the evaporator? Q2. How to get the expansion valve out, any diy pls, I searched and found nothing. Q3. Is there any other possibilities to consider? Appreciate responders. Thanks
