Search the Community
Showing results for tags 'fluid transfer case'.
  • Search By Tags
  • Search By Author
Calendars
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. Folks, On another forum I follow, there is an ongoing thread on transfer-case failures and replacements. Some people have experienced multiple failures, many people none whatsoever. One person showed a photo of his repair order, which included something interesting. Besides replacing the transfer case, they also replaced a vent hose for the transfer case. When he asked his service adviser - the adviser said Porsche had issued a WB (workshop bulletin) instructing them to replace the vent hose when the case was replaced. The open end of the vent hose was now located above the level of the transfer case, where before it ended low down on the transfer case. The explanation for this by the SA was that Porsche determined that moisture was getting sucked into the cases and causing fluid contamination. Since the Xfer-case uses a multiplate wet clutch (much like a common design on motorcycles) - I can see where moisture might cause corrosion or rust that could cause the clutch to bind and work erratically - giving the symptoms described on failing cases. So - I'm going to order and install the revised vent, and also do a preventative fluid change at the same time. Since the Porsche fluid is silly-priced (about $80/liter) - I thought I'd ask if anyone has an alternative that they've used. There are several "transfer case" fluids that I've seen mentioned as alternatives, but I'm looking for first hand experience here.. who has used what? For those interested - the PN for the revised vent is: 958-301-047-10. Roughly $30 from Sunset (least expensive I could find.. but I'm giving my FLD* a shot at it too..) TIA! * FLD = Friendly Local Dealer
