Search the Community
Showing results for tags 'intermittent start'.
  • Search By Tags
  • Search By Author
Calendars
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 2 results
  1. 1999 Carrera4. 5 years I have chased this intermittent problem. Sometimes the car refuses to start. Starter will not turn over. All maintainance has been done at a dealer service center. They say they've never seen this issue before. It's not DME they say. Every component from entire key system to the starter, as part of the security system/start permission, has been replaced. Car can go for months with no issue, start every time, then it's like a gremlin grabs it and it will not start. No error code(s) reported. Everything appears normal and proper with dash lights. Might be a minute, an hour, a day, a week... and it starts. You never know if it will start or not. Possible weak point in the wiring? Software issue? I'm flying blind on this. Has anyone experienced anything like this?
  2. Hi all, As I lurk all the time, I thought I'd post what I have going on for the benefit of anyone that can use it. Lately I've been having the dreaded intermittent cranks but won't start situation. It seems to occur mostly when the engine is warm. If left for an hour it starts up. It happens twice in a day, or not for 3 weeks, totally random. The car runs fine when its running. It's only stalled once while running. I was idling in the parking lot. Just as I noticed rpms swinging between about 780 and 730ishm dead. Started an hour later. I tried a fully charged, brand new battery one time during the no start condition and it did not help New fuel relay, no help. A DME Relay is on the way. I won't install it for a while to verify if it was the Crankshaft Position Sensor. Today I changed out the Crankshaft Position Sensor. The old one was covered in gunk and the magnetic tip was black. The new one, nice and shiny magnet there. So far so good, I'll update in a week or two. The CPS is indeed a pretty easy job, anyone can do. Just don't drop the screw in there anywhere! I stuck some chewing gum in it, smushed it onto the allen socket and gently got it started. Removing it, was the same. Slow and gentle. I used an allen socket and 1 long and one 6 inch extension put together. Reaches in no problem. I've attached a couple of pictures to help locate it. Looking from the drivers side through the wheel well you can see it as shown by the red arrow picture. Thats just the hole after its been removed. I forgot to get a shot of it in there The Yellow arrow picture shows its appearance if you were to slide under the car from behind, head first and just to the inside of the drivers side wheel well. I've outlined the wire and labeled the CPS B (from the red picture) and the plug end "A". The plug has a little lever tab on top that you can't see, Feel for it and push it down to disengage the plug. You can totally get at it if you contort properly, no big deal. That black plug to the left of it is something else and it made life easier to pull it out of its clip. Pretty sure it just pulled straight out. Anyway, for what its worth. Fingers crossed its the CPS or the DME Relay next. If not, I'm headed towards fuel pump I suppose.... -= Jazz
