Search the Community
Showing results for tags 'oil leak cylinder head'.
  • Search By Tags
  • Search By Author
Calendars
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. Having a problem with sudden massive oil loss on my 01 996 C2 (86k original miles) . Here some of the background. it is ca. 900miles since IMS/RMS replacement. Perfectly runing car, no codes, no leaks. Since I am new to 911, I was wondering about oil consuption - which was ca. 2 quarts (I thought my Cayenne CTTS consumes plenty of oil (>1Qt/1K is normal)) , but to my surprize, from discussions with local fellows with air cooled 911's , I can expect a quart / gas tank on a carrera engine ) . So I thought a quart / 450 miles (about two tanks) is not unusual. I also noticed no leaks under the car at any time. What I was concerned , however, was about the recommendation to use the M1 5W-40 diesel truck oil (Which I used since the IMS/RMS work). Reading through misc oil threads, I ended up w/o a clear direction (except to do it 5k or less intervals) , and decided to try what Porsche recommends - and this is 10W-40 for the climate I am in - with 50-60F. So, I swapped the M1 5W-40 dt oil after less than 1k miles for M1 10W40 high mileage oil. The dip stick showed max./ the dashboard gauge was in middle . The car ran perfectly fine for ca. 50 miles (a day commute to office). This afternoon I drove the car slowly for about 10 min (just to local store a few miles away) and once back home I parked the car curbside for about an hour. Then , while parking the car backwards on driveway , to my surprise I saw a major oil puddle of ca. 4 sft caught my attention just below where the engine was sittiong above the last hour. Double-checking driveway shows not the slightest signs that this could have started before I started the car today less than an hour ago. Backing up the car onto garage (engine does no unusueal sounds while doing so ) , and checking oil-level. The dashboard shows 2 bars above min (which is about one less since I filled up last). Dipstick, however, shows barely above min. Checking the floor, I see the oil dropping from rear cross bar. Jacked the car rear up and identified that all is perfectly dry around Trans Bell-housing (my first concern, but it confirms to me RMS/IMSB area is not guilty here). However, there was oil deposits on LHS Drive Shaft, car underbody above , and all in the plane in line with left cylinder head gasket . I wiped the head gsket area dry, but which shortly after leaked oil again @ lowest point of left cylinder head (engine off....). I am confident by now is that no mix of coolant in oil or vice versa. What I am puzzled about is that all seems to have started since I switched to the thicker Oil at lower temp two days ago. My question is whether the situation is more or less known / whether I can still diagnose / fix leak from "outside" , or do I need to drop the engine and start tearing the engine down?
