Search the Community
Showing results for tags 'variocam plus'.
  • Search By Tags
  • Search By Author
Calendars
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 2 results
  1. Hello together from germany. M96.05 is in a VW Beetle 72, as a middle engine with Boxster S Transmission. There is placed a free programmable ECU Ecumaster black. I would be really happy to receive some important information: - parameters, if valve lift is low or high - variocam is not only retard-advanced, like models before, but stageless (i think there are 3 or more stages definied) how does the activation work to the solenoid? With one cable, should be PWM. It would be helpful to know the frequency of the PWM. Sadly, i have no car available to test around and measure... A map for the cam adjust would be very helpful. - ignition maps would be perfect, in dependence of Valve lift and cam advance and everything ;-) If you cannot help me with the detailed information, i would start like: - soft ignition table - valve lift high from 1800rpm to the end (take/give 100rpm) - cam advance from 1500-5500rpm, going more advance in the middle of that What do you think of start like that? Regards, Olli
  2. Hello All, In some time I have to take the NA 3.6 cam cover open and remove cams, so I have been looking for and reading the 3.6 cam timing instructions. I have done the older VC F1 timing earlier, but the VC actuator is different here and so is the timing procedure. What I have not found info of is the VC + actuator allocation to neutral / park. I found similar allocation info from 3.6 turbo manual, but not from normally aspirated one. My understanding is, that the VC+ valve (3/4 valve) will close all ports when power is shut down, thus it would keep its position, untill the valve is commanded to retard or advance. Thus would it be needed to park / turn the actuator to neutral (0 advance?), before initial tightening to the cam and timing the cam system? Basically the cam allocation. I have tried search, but maybe my tag words are wrong or I have missed something. Car in question is: 2002 996.2 Coupe 3.6L BR, Jussi
