Multiple codes found with Durametric
Just did a scan with my new Durametric and several saved codes besides the one I was going to the dealer with about PASM (1772) discussed elsewhere. Found several under Motronic- P0011 (camshaft position), P00300 - multiple misfires, P0307, P0302, P0306, all for specific cylinder misfires. These did not throw a CEL but does this mean I need the coil-packs replaced?? Also 1542 under PSM - rate of turn sensor... boy, at 43K I don't want these going off after 50K!!!'
Looks like the dealer has some work to do...
Hi
a) most of the V8 engines have got this timing problem.It is adjustable,but commes back without fail.
B) replace coils,clear codes.
c) each time the battery was disconnected,this code appear.Drive a little bit and claer the code.
It is not so bad as it looks .
Regards
