The driver window on my 2000 rattles, clunks almost, when the top is up and I hit a hard bump in the road. It doesn't happen when rolled-down the tiniest bit. I've looked for missing gaskets, seals etc. but not found anything. Any ideas?
TI.
Jef
Probably too match play in the window mechanism, all what you can do in this case, is replace the mechanism.
TI.
Jef
I had the same problem. The glass developed a small play vertically and horizontally which I only realised when I compared it with the window on the other side. I had to replace the window frame part# 996 542 075 04 around 150 euro
Thanks. Is this problem caused by opening the door before the window does its annoying little drop? (BTW, I've always been very careful to let the window drop before opeining the door, but the previous owner may not have been so careful/patient.)
