I will be adding a bluetooth module to my 987 at the weekend and have figured out nearly all needed connections at the CDR24.
A:
A2: ASK Amplifier - could be used as switched power
A3: Telephone Mute
A4: power
A8: GND
B: Loadspeaker
C:
C12: Telefon NF GND
So the BT module will mute the radio but I don't know where to connect the loadspeaker output of my BTmodule so that I will hear the voice over the cars loadspeaker.
does anybody know where to connect it?
Please HELP, I do not want to install an extra loadspeaker for this hands free option!
Thanks, Boxsterthommy!
Not sure which Bluetooth device you are adding but generally with most non radio specific bluetooth modules they connect the audio via inline speaker connections i.e. you disconnect the headunit speaker connections from the car wiring and then connect headunit to Bluetooth and then bluetooth to care speaker connections.
This is just general info so hope it's of some use, it might stop you searching for an elusive audio in connection :-)
Alistair
Alistair
Thank you for your reply. I found some information on that topic somewhere else and will be installing the BT module next weekend if I have time.
