Has anyone tried to retrofit their Fog Lights with HID lights? or can it even be done?
I suppose it could be done, as long as you can find a HID that has the same style of bulb, but...
I your car is like mine the voltage being sent to the fog light is not a constant 12v, it is modified by the OBC, and if this is the case you would have to run new power for the ballasts as well.
Check my post in the 987 section of the forum for the efforts that I went through to install a HID kit into the stock halogen headlights... http://www.renntech.org/forums/index.php?s...20&start=20
Edited by Westcoaster
