Hi, 97 boxster with 120 K miles. New O2 sensors and old catalytic converters. Reading after cat on one side is .7 volts but reading after cat on other side is .07 volts. Which reading is off spec? Is one of my cats going? Readings before cats fluctuate between .2 and .7 volts as they should. Car runs fine. Have tried changing 02 sensors with no change.
Thanks, Dave
