Can anyone offer any insight on how to unlock the rear seats. I just picked up a 2003 Cayenne S and didn't think to see if the rear seats would go down. As it turns out, I believe the release levers for both sides are broke (or frozen). I've tried several times with no luck. Can anyone offer any insight as to how I may take them apart??? Any (repeat ANY) assistance is appreciated.
You can unlatch the hook with a flat screw driver on the back, once the seat is in the open possition, give a look to the latch mechanism and grease them, replace ALL the plastic parts, they are broken no doubt about that.
Are you getting the front part (seat) folded forward against the front seat first? You have to pull UP to unlock the seat part to fold them forward...just a thought, it took me like 3 days to figure out how the seat part folded forward.
  • 4 weeks later...
THANKS! That did the trick. Now all I need is a Torx bit so I can take the plastic caps off. Mahalo and Aloha!
