In addition to having to hold the stalk in the up position to signal RIGHT, when I signal LEFT, it stays in place, but it doesn't click back to the neutral position when I turn the steering wheel in the opposite direction. Needless to say, I believe the mechanism that the stalk is attached to is broken. I took apart the steering column cover to investigate and a little plastic piece fell out. Can I replace the whole mechanism? How can I do this? Thanks in advance! (2003 C2 Cab)
