Depends on depth of scratch
If you cannot feel it with fingernail then normal polish should take it out (Meguiars Cleaner Wax for example)
If it can be felt but is not through the clearcoat then try cleaner wax again, before moving onto more abrasive types.
If its into the silver then you will need to replace the clearcoat locally before buffing with an abrasive compound (again start with gentle compound and work up)
If it through the silver then need to replace the silver and the clearcoat - this can be done if you're patient with nothign more than a broken matchstick
