Response
00 boxster 2.7 58k tiptronic.
Note: new spark plugs , new air filter , new AOS.
This doesn't happen all the time but does happen occasionally. I would press the gas paddle mid way expecting the car to just go, but instead I'm getting nothing, it doesn't choke or hesitates it just goes at a very low accelaration rate , it noticably happens when on low speed (around 28-30) and gear indicator shows 4th gear.
I would expect the trans to drop the dear and go but it doesn't.... I'm not sure if its me being too gentle on the paddle or some other issue.
:renntech:
Edited by sc00ter18
So on my way to work i was able to pin point exactly how this happens.
from stop , i start driving with medium acceleration , the car shifts to third , i will then press the gas harder and the car will not respond to that , almost if it actually slows down rather than go faster.
