window not dropping
hi everyone...... i'm new here and already asking for help
just bought my first boxster 5 days ago year 2000, 2.7 and already got a problem, hope this isnt a bad sign.......... when opening the drivers door from the outside the window has stopped dropping down until the door is open about half an inch, everything works fine from the inside ( window falls down immediateley ).... is this straight forward to fix....
thanks in advance folks........
steve g ........ from a sunny england
thanks toolpants....
will try this in morning matey, just got home from work. need a drink and supper...
i presume if i dont hear it click it must be out of adjustment..............
is it easy to adjust / get at............ ?
thanks again
thanks blee..........
i think the problem lies with the switch being o.o.a compared to the passenger side.
i have to lift the handle right to the top..... only slight inconvenience.
when i have more time i will remove the door panel and hopefully adjust..........
