It's time to play that game again, "What Just Fell off My Car?"
When I pulled the Boxster out of the garage, it left this behind, it was setting near the front of the car. Can anyone identify this little rubber part?
Edited by blue2000s
I like these trivia type questions. But most of the time it tuns out some object found near your car has nothing to do with your car.
The last trivia I remember was this part. Turned out to be a part from a garage door.
Grommet front middle radiator fixation.
Are you talking about 930-113-430-00-M136
If so, that's not quite the same, plus it looks like that part is only for the tiptronic, mine's a stick.
Edited by blue2000s
Yep, after you inadvertantly drive into puddles during winter rainstorms. It is probably for the trunk area, that's where they
tend to be located. :)
Doesn't look dirty enough to have been a drain plug, exposed to all the elements under the car, what would cause a grommet to randomly come out? as Tool pants said, it is from the car right?
I've looked around my car for a part like that to no avail.
I don't think its from the car. Maybe the washing machine??
Is it possible that it is a jack pad from the last person who jacked it up?
Maybe it was stuck int the jack point hole?
