I'm about to troubleshoot a non working Egas Pedal. No CEL, just does nothing.
My plan is to check the wiring and connectors to the gas pedal sensor and the throttle switch.
Where is the gas pedal sensor?
Edited by Paul in WI
Integrated in the accelerator pedal or in a box above the pedal ( controlled by a short steel cable )
Yes I found it, it's above the cluster assembly.
