Well last night temps dipped into sub zero's here and the heat takes a long while to get hot..how is the heat in everyonelse's cayenne? my gauge is in a good range but heat is not as hot as a i liked..can i bleed the system by simply removing the coolant cap and letting it over flow?
I had a similar issue. The lower footwell vents were not coming on. They replaced the aircon controller and that fixed it.
