Yet Another Valentine 1 Dome Light Hardwire Install
Valentine 1 Dome Light Hardwire Install Disclaimer: As per previous threads, this is a simple and easy install, but, tapping into the domelight hot wires will cause the detector to turn-off and on when you open or close the doors, for example. If this bothers you, then hardwire to fuse box as per other threads.. ( I think Coochas on 6 speed recently posted and fuse box hard wire DIY). A) Remove dome light console by gently popping out 2 remote buttons with a small flathead screwdriver. Two phi
