Need help. 2004 Cayenne S Cyl 5,6,7,8 Misfiring
I have problem with my 2004 Cayenne S. In the beginning it runs rough (misfires) without CEL. After I revved it higher the CEL appear and than begin to flash. Car heavily misfires. I looked at the Renntech forum and I was almost sure that it is coil packs problem. One of the coils was melted all have cracks. I replace all 8 coils and sparks ( as my car has now 60k. )
Unfortunately it doesn’t help ☹.
I read new OBD fault codes:
P0273
P0276
P0279
P0282
P0300
P0305
P0306
P0307
P0308
P0355
P0356
P0357
P0358
It appear as whole bank 2 problem. Coils and Injectors. But coils are new. Is there any possibility that hole bank was shut down as a result of coil failure. (any fuse that can be burnout)
Please help.
Best regards
Mark
Maybe change out the spark plugs. Do not drive or operate the vehicle if the MIL is flashing. There are no fuses for the ignition coils that I know of.
Thanks for replay.
I have already changed all 8 sparkplugs and coils. Now result :-(
Look out, there are fuses for bank 1 and bank 2, the fuses covers the coils and the injectors on the same Bank. There is one fuse blown causes the melted coil, the engine runs on one Bank now. The fuses are located in the fuse/relay box under the trim in front of the windscreen left side of the car.
Huge thanks RFM :thankyou: :clapping:
You were right. It was that fuse. Now the car runs great.
After schort run i reed OBD faoult codes and ther is one code P0021 is there anything to warry about?
Regards
Mark
maroo,
The timing ( possition ) of one camshaft is not consistent with the crankshaft possition, i would ignore it, for the moment, and clear the code, recheck the codes in a week or two. A lot of Cayenne's have this error due a slight stretched timing chain, you can rectify the timing if you have the knowledge and the tools. Not a real DIY.
  • 4 years later...
My 2004 Cayenne S seems to have the same problem.
"Emission Control Warning Light (Check Engine)" light came on (steady on) for the second time - first time was January this year. It occurs on the same driving pattern and symptoms. After the first time, my mechanic replaced the spark plugs and swapped coils of cylinder 3 and 7 and the problem went away.
The problem came back yesterday and here are the symptoms:
1. Begins with a cold start - or cold start then short trip (say under 15min driving) - then restart the car after engine turned off for about 45 minutes to 1 hour. My car is very low mileage.2. Lower engine idling revs with vibration.3. At city speeds the vibration would get worst as driving speed increases. Take it onto the highway it will vibrate more.4. "Emission Control Warning Light (Check Engine)" warning light would come on after that 1 hour pause when I am away from home shopping, etc.5. Cannot repeat the problem consistently.6. Replaced all 8 spark plugs and now the problem came back.7. Since day 1 I own this car, I have the "lurching from cold start" issue but never resolved or mentioned.8. Switching off and then switching on the PSM seems result in the PSM stuck electronically at off resulting in an increase in the gear change rev speed regardless if the PSM is off or on.Error Codes found:P0357 Ignition Coil Primary/SecondaryP0307 Cyclinder 7 Misfire Detected
Same problem with the fuse? If so, which fuse in the fuse box to check?
If not the same problem, what are the likely problems and is this a DIY with a professional mechanic or it has to be done at the dealer?
Edited by rting
  • 3 years later...
