Hello everyone. I'm trying to install lowering springs on my 997 C2... so far without much luck. I'm looking for instructions to do the job right. Any suggestions? Thanks.
If you are not familiar with the fitting of the front upper bearing and washers, it's better to remove the struts and do the work on a bench, you have to remove the rear ones anyway. There should be some instructions on the 996/986 forum.
