Can someone give me an idea where the neutral safety switch is located on the tiptronic? My higher lift jack broke so couldn't get the car positioned the way I wanted to really dig around under the car. Going to tackle next weekend but wanted to narrow down the search if possible. Do I have to drop the plastic pan under the car?
2002 C4 Tiptronic
It work easier with the plastic plate removed, the switch is located on the gearbox side, follow the wiring.
