Right fog light very low brightness and right blinker works sometimes. Relay buzzes but blinkers works great using emergency button. Changed fog buld nothing changed.
Looks like a ground problem, check the bulb fittings and the connector on the rear of the unit for proper fitting and corrosion first.
