Weather is getting warming this week here in the SF. When I need the air conditioning and found out it doesn't blow cold air. It is a 2005 Cayenne S. Few weeks ago, I noticed buzzing noise at the airco fan under the passenger side area. I thought that was no big deal becasue I have heard that the fan was a common issue. I was thinking have to replace it in the wrost case. Today, when I lower the temperture of the climate control, the air blowing was still warm. Of course, I checked the fuse at the right side panel and it was okay.
Any suggestion before heading to the dealer? Should I replace the fan anyway since it has started to make noise? Thanks.
If the fan motor is making noise it's best to replace it. As for the other problem it sounds like you may have a leak in the refrigeration system.
