I did my rotors/pads but did not install the wear sensors at all (disconected at the wheel carrier) . Now my dash light is on. Will just plugging in the sensor get the get the light to go out (leaving them out of the pads)? I assume I can run this car without the sensor? Thanks
To make the dash light go out, you have to plug the end of sensor back into the wheel carrier, but you leave the sensor out of the pad. I use wire ties to coil up and secure the wire so it doesn't get caught in anything. At least, this is what worked for me.
