Hi All
I see in the PCM manual that, if you have some optional extra, you can change the remote key to only unlock the driver's door. My wife used to have this on her SLK-350, and would like it enabled on her 997 C2S Cab. Anyone know how to do this, or if the dealer can reprogram it?
pete S
I'm pretty sure I saw the uption of unlocking the driver's door only when I was coding window operation with the PIWIS tester, so the dealer should be able to program it. I don't know if it is possible to do it yourself.
Where are you located? There might be a RennTech member locally who could help you out. Look in the diagnostics forum, as there is a register.
Hi Richard
Thanks for the reply - I'm close to Reading, and the car's got to go into the OPC next week, so if it's a PIWIS option, I'll get them reprogram it.
pete S
