I accidentally pushed my trunk latch button with the edge of my Dan Post boots and pushed the button
all the way into the side panel on the driver's side.
How do I get that panel off to put the button/switch back??
I pulled out the two little plugs on the side of the panel, only to find no screws or bolts just carpet.
What is the trick to getting that panel off??
Thanks for the help. :renntech:
There are Allen bolts behind the carpet, push the carpet downwards with the Allen key through the holes, then you can enter the key in to the bolt head, loose the bolts 2 turns and pull of the trim (5 mm. Allen key if I'm correct)
