A/C leaking, drain hole location
If you remove the trim under the glove box, you will find the drain near the fire wall.
Thanks, found it by peeling back the carpet. Pulled it out and stuck it back in the hole and now it drains. I guess it's a dedicated drain.
f^&%*ing dealer said they wouldn't fix it unless I had 30k service done there because they claim they clean drains as part of their service.
Not only did the drain not need cleaning (it seemed to be pinched under the carpet backing) there's no way they clean a dedicated drain as part of service.
