Hi there,
I need your advice if anyone had this problem beforem, my ctt04 is struggling to drive when i push the gas, it seems like no enough fuel going in there or the engine over filled with fuel....
when i try to start from zero while accelration there will be no response at all and suddenly response will come back,, i noticed some noises comes from under the car like (puff puff) usually this noise comes from cars with no fuel as far as i know...
i smelled fuel smell when stopped from mufflers....
my wife noticed when i strat the car black smoke comes out of the mufflers ( just when starting and not all the time)
i would really appreciate your help
Any check engine lights? It's best to check for codes and post them here to atleast give a starting point.
sounds like coils/plugs
Hiere,
Hiere,
My car is done around 125,000 K/M plugs and coils were changed at 110 is it possible they need to change this fast?
Do what wvicary suggest, let check the car for fault codes, without the codes it's a guess.
