2004 986S dedicated track car
DME 7.8 - e-gas
Yesterday at Sebring, in the afternoon sessions, a few times when I mashed the throttle, nothing happened. No increase in revs. I would let off, mash again, and it would go - or maybe I would have to "pump" once or twice and then it would go. Never shut off - idled fine.
I know I have a bad o2 sensor in bank 2. I just didn't have time to replace it. A new one is on its way from Sunset. Could this be due to the bad o2 sesnsor or does this bring to mind something else? No other codes than 154 and 155.
Other things that have occured to me for comment -
* RFM said one time the fuel pump on track cars can get overheated and have issues - it was really hot - over 90 degrees and it was OK in the first two sessions (slightly cooler), only started around mid day, and did it at sessions when hot as opposed to the start of the sessions
* accelerator pedal module - wonder if there is a fault in the module, which I understand translates the cables position to an electrical signal to send to the throttle body - no codes though
Thoughts?
It could be a traction control fault.
Interesting idea - however, I turn PSM off, and we are talking about end of session when I am not stressing the car.
