I am reinstalling my RemoteKey module in my 09S PDK. The original wiring directions had me tapping into existing wiring, which threw codes.
I want to reinstall by plugging into fuse block for power, no problem, But I need a good grounding place.
I would welcome a suggestion, before I retap into another unknown ground wire.
Edited by larrytrk
If you pop the side dash cover panel out (pop out the rear edge, then pull back), I like to use one of the dash support bolts, it's a good ground point. I don't like using the nut on the left side of the fuse box since it's holding down plastic. Just personal preference.
